15 years agoPLLs could be used to reduce the influence of noise ?
Hi, I remembered that i read from somewhere that 2 PLLs can be used to reduce the influence of noise during data transfer? or during FIFO rate matching? when having 2 external clock source. ...
15 years agoAlthough I have seen it work at removing noise, I wouldn't rely on it for that, i.e. the system shouldn't have clock noise to begin with. And if it loses lock(and allowing the system to see the problem) that is a lot better than a double-edge inside the fabric.
