15 years agoPLLs could be used to reduce the influence of noise ?
Hi, I remembered that i read from somewhere that 2 PLLs can be used to reduce the influence of noise during data transfer? or during FIFO rate matching? when having 2 external clock source. ...
15 years agoInteresting....
So using PLLs are common practice in filtering out surrounding noises? otherwise, what are other option of doing so? Thank you for your reply. Regards, Michael
