17 years agoPLL Reconfiguration problem on Cyclone3
In our design I have to reconfigure a PLL when we change from SD to HD video mode and back. (27 and 74.25 MHz input, and different output clocks.) For some reason clock stopped working and the onl...
17 years agoThe best way (in my opinion) to dynamically reconfigure a pll is to use the "altpll_reconf" megafunction.
I feed my pll with a 24MHz clock and the "reconf" block with a 6MHz clock. I also use ROMs ("altsyncram") to store the data to reconfigure the pll. The "altpll_reconf" create "pll_scanclk" which is used to feed the ROMs. Pulse, one pll_scanclk cycle, on "write_from_rom", wait enough time, then pulse on reconfig, one pll_scanclk cycle again. It works for me with clk from external signals or from another pll. Second thing, make sure your design is clean. When you copy a folder with a design inside, quartus do a lot of bad links. So make sure that all your .vhd are well linked, that there are no problem with the "inst&&&" etc... This could make several strange effects. for example, one of my design mixed the output of my pll after reconfig, and make a cleaned project solved the problem. good luck!
