9 years agoPLL outputs on 3.3V IO bank of CycloneIV
Hi : Is it allowed to configure pll clock outputs as differential mode when the bank IO voltage is 3.3V. If so, does VCCA provide the +2.5V for this kind of LVDS mode? Is it sa...
9 years agoOutput drivers are powered by bank VCCIO, there's no supported 3.3V differential I/O standard. What you can probably do is to assign fake 2.5 V VCCIO to the bank and use a 2.5 V I/O standard with reduced performance. Particularly a differential standard with external resistors should work.
