15 years agoPLL output square wave distorted
I am testing PLL output from an old Stratix board. The PLL has an onboard 80MHz crystal as input clock. However at > 60 MHz, the PLL output is not as square as I wish with ripple and 50mv u...
15 years agoMy scope is tek TDS5034B, sampling rate is 5G/s.
My stratix board have an SMA connector for PLL output, from which I use a SMA-BNC adaptor + BNC cable to the scope. all cable and connector should have a bandwidth well beyond 2GHz. Anybody have monitored your PLL output at high frequency?
