PLL Integer mode vs Fractional modes in PLLs (Cyclone10 transceiver)
- 4 years ago
Hi, sorry to keep you waiting.
Arria 10 FPGA has 2 types of PLL : Fractional and Integer PLL.
Fractional PLL is used when you want to generate a uncommon clock frequencies with fractional numbers such as 6.625Mhz, 3.125Mhz etc clock frequency.
Integer PLL is used when you want to generate a common clock frequencies like 10Mhz, 25Mhz, 125Mhz etc.
how to use and set fractional PLL is shown in this link:
https://www.intel.com/content/dam/altera-www/global/ja_JP/pdfs/literature/an/an661.pdf
and this document shows how to calculate Fractional PLL divider value during setup:
while integer PLL is more straight forward setup, this is the documentation of it :
If you are new to PLL in Intel FPGA, I would suggest you to get familiar with integer PLL first, then slowly move to Fractional PLL.
best regards,
Farabi
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
best regards,
Farabi
