15 years agoPLL frequency lock range
Hi, I have a serial video signal that I want to take into an FPGA, with a parallel clock that could range from about 20MHz up to 150MHz. I'm using an Arria II GX. Am I able to get the PLL in th...
15 years agoAlex,
The easiest way to handle this is to feed the data and clock into dual clock fifo. This allows the input data/clock to vary to any value. Then you can process with a fixed clock on the other side. No changes in the PLL input frequency.
