18 years agoPLL dedicated external clock output pins in cyclone II EP2C20F484c7 FPGA
hi all, I am using Cyclone II FPGA Starter Development Board which contains cyclone ii ep2c20f484c7 FPGA to drive 800*480 color LCD. For external interface with LCD, i am using the two 40 ...
18 years agoYou should use the pin that is connected to LCD clock input, if it's dedicated clock output or not. If it's a dedicated clock output, it can be used also with single ended IO standard.
