15 years agoPLL? Cyclone ii? I/o
Is it possible to use the Cyclone ii PLL to divide down a 37.5Mhz clock on a standard input/output pin. Does it need to be on a dedicated Pin?
15 years ago --- Quote Start --- I did get a DE-2 board and it was very helpful. --- Quote End --- Ok, great. These are nice boards, with lots of peripherals. You will also be able to get lots of example code. --- Quote Start --- So far Ive made 2 successful circuits that work great. I use Verilog exclusivley. --- Quote End --- Once you have got some basic circuits working, you'll want to create components with 'standardized' control interfaces. In the Altera-world, these components adhere to the Avalon bus specification. In some cases you can use Altera-supplied IP, while in others you will need to develop your own. Part of the development process involves simulation of the components using the Avalon Verification IP suite; its written in SystemVerilog. Take a look at the Altera documentation for these, and ask questions when you need help. There are a couple of good Altera webinars on these topics. Cheers, Dave
