15 years agoPLL clock output
Hi, My design needs the PLL-clock output to be mapped to non-dedicated clock output pin of FPGA. When I do so, the following error message appears. What would be the best solution? War...
15 years agoIt's not an error - it's a warning which you are guaranteed to get when driving non-dedicated pin with PLL output. If this is what you intended to do, you can simply ignore this warning.
