18 years agoPin assignment wrong on ALT2GXB
I've been working on a design project in Quartus and am having some difficulties with assigning pinouts for a Stratix II GX on ALT2GXB. Error: Can't fit design in device Error: Can't place i...
18 years agoIf you look at your synthesis report you will find the following warnings:
Warning: Synthesized away the following node(s):
Warning: Synthesized away the following SERDES transmitter or receiver node(s):
Warning (14320): Synthesized away node "FORWDGXB:inst2|alt2gxb_forwd:inst2|alt2gxb:alt2gxb_component|rx_out_wire"
Warning (14320): Synthesized away node "FORWDGXB:inst2|alt2gxb_forwd:inst1|alt2gxb:alt2gxb_component|rx_out_wire" Your problem is as dewiet pointed out. Your ALT2GXB instances are being synthesized away and Quartus does not allow you to declare transceiver inputs in your design without connecting them. Jake
