9 years agopin assignment problem
Hi, I am new to quartus ii. I have created a bdf file instead of verilog/vhdl . i am taking input through terasic data conversion card and through sma cable i am giving a sine wave but i am not...
nitropython
2 years agoThe pin assignment software for Quartus prime is infuriating, I am trying to learn with the DE10-lite and it's amazing how much time I have wasted. Pin assignment should be as easy as uploading a file, somehow the assignments in the editor will check mark green then eventually change to ?. The information for these issues is sparse and the reality is this should be a not be an issue. I am not recommending anyone waste their time with the info above this is beyond frustrating.
sstrell
2 years agoYou should be using the Pin Planner instead of the Assignment Editor for this.
And you probably should start a new thread in the forum as well.
- nitropython2 years ago
Intel docs in the learning material says the opposite...
