9 years agopin assignment problem
Hi, I am new to quartus ii. I have created a bdf file instead of verilog/vhdl . i am taking input through terasic data conversion card and through sma cable i am giving a sine wave but i am not...
9 years ago --- Quote Start --- Have you at least synthesized the design? You can't make assignments until you do. How are you trying to select the signals in SignalTap? Are you using the Node Finder? If so, are you using one of the SignalTap filters (pre-synthesis or post-fit) to select your signals? --- Quote End --- Hi, Yeah i have synthesized the design. i have selected signals using node finder and using post fit filter Thanks!
