15 years agophase difference 2 signals.
is possible whit fpga FFT or similar metod measure a phase difference from 2 PULSED-sinusoidals signals? the freq of signals is 60MHz but the duration of signals is 0.5uSEC, and the PRF of pu...
15 years agoIn principle it should work. in terms of resolution it depends...
You can think of the idea in simple time domain terms as follows: your ref is: sin = 0,1,0,-1, cos = 1,0,-1,0 if your signal is exactly in phase with sin then you get: Re = 0,1,0,1, im = 0 i.e. double frequency (120) plus dc if your signal is exactly in phase with cos then you get: Re = 0, im = 1,0,1,0 if your signal is in between then you get a value indicating where it is in phase. As regard amplitude, the same applies in relative sense to sin/cos amplitude. To read the phase you can either compare the vertical components (Re/Im) directly or have an LUT to convert to degrees.
