15 years agophase difference 2 signals.
is possible whit fpga FFT or similar metod measure a phase difference from 2 PULSED-sinusoidals signals? the freq of signals is 60MHz but the duration of signals is 0.5uSEC, and the PRF of pu...
15 years agoThat is difficult to judge unless you model you case.
Demodulation as FvM mentioned imply (as I believe sin at 0,1,0,-1 and cos at 1,0,-1,0) i.e. multiplying by 60 MHz and thus you get your frequency moved to zero(60 - 60) with an image at 120 (60 + 60) and this will need filtering I believe. If you multiply by +1/-1 sine instead then you get your frequency at 60MHz with image folding on your frequency and no need for filtering But you can't generate sin/cos at +1/-1.
