15 years agophase difference 2 signals.
is possible whit fpga FFT or similar metod measure a phase difference from 2 PULSED-sinusoidals signals? the freq of signals is 60MHz but the duration of signals is 0.5uSEC, and the PRF of pu...
15 years agoIf you have matlab, you can try this code (not tested):
%assuming Fs = 240Msps %signal 1 offset = 100; x1 = sin(2*pi*(0+offset:200000+offset)*60/240); x1(1000:1000:end) = 0; %switch off %ref xref = sin(2*pi*(0:200000)*60/240); y1 = fft(x1,1024); y2 = fft(xref,1024); A1 = abs(y1); A2 = abs(y2); ph1 = angle(y1); ph2 = angle(y2); you will then check A/ph at relevant bin
