15 years agophase difference 2 signals.
is possible whit fpga FFT or similar metod measure a phase difference from 2 PULSED-sinusoidals signals? the freq of signals is 60MHz but the duration of signals is 0.5uSEC, and the PRF of pu...
15 years agoIs there any reason why these two signals are pulsed sinusoids?
If this is a ranging application, then an FM chirp (linear FM pulse) would be more appropriate. Pulse compression of the FM chirp (correlation) then results in delta-function like responses (with a width determined by the pulse bandwidth). The 'time delay' between the delta functions can then be determined. Pseudo-random sequences can also be transmitted and pulse compressed in this manner. What are you trying to do? Cheers, Dave
