15 years agoPFL with S4 and MAXii
Hi I encounter an issue while using a PFL (FPP) configuration scheme. Actually: -- the Flash memory is correctly seen by the CFI and well programmed -- the configuration has the following be...
15 years agoHi,
Thanks for replying! Actually, I wonder if you could still send me your design and schematic. I used a board from Hitechglobal, and I am having a little trouble to implement the re-trigger configuration for PFL. Cheers, Han
