15 years agoPFL with S4 and MAXii
Hi I encounter an issue while using a PFL (FPP) configuration scheme. Actually: -- the Flash memory is correctly seen by the CFI and well programmed -- the configuration has the following be...
15 years agoThe FPP mode requires 2 clocks after the completion of data in order for the device to complete the configuration process.
This may be the issue you are seeing. I know it was with our Cyclone III LS design. Pete
