10 years agopcie for dummies
Hello to all. I would need a text on the fundamentals of the PCIe. I would like to study the concepts of Endpoint, Root, and Protocol. I'm using the example hip_cvgt_g2_x4_avmm_dma128_1602....
10 years ago --- Quote Start --- PCIe is not master/slave. As long as the system is set up correctly the endpoint can master the bus and read/write the PC's memory space, such as main memory. --- Quote End --- I thought that was the case - but I only used it in a simple set up with the dev card only acting as a slave - as a port to a dual port ram between PC and another processor. What was difficult was having only an avalon streaming port as the stand alone hard core (not using Qsys) would only provide a streaming output. Here I had to write logic to decode and reply to the packets. Hence the reason for the book.
