15 years agoPCI interface with FPGA
Please if anyone can guide me how to input the data in FPGA through PCI interface i will be obliged if u tell the steps to follow regards uzmeed
15 years agoHi uzmeed,
--- Quote Start --- I know a board with FPGA and ADC on it ( agilent) --- Quote End --- What is it? --- Quote Start --- but the problem is that i have to build the communication of ADC and Fpga MY SELF so looking for two seperate boards thats why i asked wat are the possible aspects of VME interfacing with FPGA --- Quote End --- There is difference between 'communications' with a board over VME or PCI, and transferring all the data from the ADCs over PCI. Your earlier posts indicated you wanted to stream the ADC data over PCI, and this you cannot do, there is simply not enough bus bandwidth. The same goes for VME. The design of the ADC interface to the FPGA should be fairly simple. Provide details on the Agilent board, which I think is probably an Acqiris board - right? If so, these boards use Xilinx FPGAs, so for design help, you will have to find a Xilinx forum. If you want to get data from that board, you will need to purchase whatever IP Agilent has for getting data from the ADC. The big issue with commercial boards like this is they usually want big bucks for their IP. Cheers, Dave
