15 years agoPCI interface with FPGA
Please if anyone can guide me how to input the data in FPGA through PCI interface i will be obliged if u tell the steps to follow regards uzmeed
15 years ago --- Quote Start --- i have found another ADC struck.de/sis3301.htm and the interface is VME please guide that can it ful fill my need and wat can the posible issue for interfacing VME bus to FPGA spartan6 or V5 --- Quote End --- You're going about your system design the wrong way. You first need to describe what you need to do, and then look for hardware. You cannot 'stream' ADC data across PCI or VME backplanes with any decent bandwidth. These buses are shared, so if you have a system containing multiple boards, you will get bus access contention. Please describe what you are trying to do, and I can offer suggestions. BTW: This is an Altera group. If you want boards with Xilinx Spartan devices, then you should go find a Xilinx group. However, you can still describe the system and I will help describe what you need to do next. Cheers, Dave
