18 years agoPCB question
I am almost done with my PCB design, the "soldermask" pretty much doubles the price for the 2 prototype boards. How criticial is that for a first project? Can I solder it all together without the mas...
18 years agoTo my opinion, the minimum requirement is a meshed ground net with low inductance bypass capacitors at each supply pin. Although no high-speed I/O is involved, signal quality of input clock and configuration/programming circuit may be an issue as well. If PLL usage is intended, it's supply bypassing is another, even more critical point.
