13 years agopc to altera gx transc
hello i am trying to learn how to use the stratix gx transceiver
i would link some info on the gigabyte ethernet mode if it can be used to transfer data from PC to fpga how is it done ? and where can i find some premade examples or documents please? the application i to send about 500 000 number from pc to fpga sequential sorters5 Replies
i currently have this altera kit at the university: altera DE2-70
i will try to mimic the example on the avaible resources on this board - Altera_Forum
ok thank you i will try that :D
There's an awful lot of bookkeeping required to establish and keep an Ethernet link going. You're looking for performance, so what I would suggest is use the NIOS for basic link establishment and management but use DMA to transfer the payload into your own logic and back again. Have a look at: http://www.altera.com/support/examples/nios2/exm-ethernet-acceleration.html Otherwise you're looking at implementing the whole protocol stack in logic rather than software. Mark. - Altera_Forum
thank you
this creates a nios-like configuration in the fpga ? then it would be easier to user the transciever ? fpga--> nios--->pc ? - Altera_Forum
Have a look at: http://www.altera.com/support/examples/nios2/exm-net-std-de.html That should give you an idea and get you oriented. Mark.
