18 years agoPC software for FPGA control through USB port
On one side you have developped a PC control software (i.e. Visual C++ .net application). On the other side you have a Cyclone III development kit. What is the best/simplest way to make them communic...
18 years agoThanks for all the information. It opens more and more options but it also rises more and more questions.
I have now 3 options : USB + control software, Ethernet + control software, Ethernet + webserver. At the end, I think my product can live with any of these 3 options but further to your comments, I am now a lot in favor of the Ethernet options. The main issue for me is now to identify THE solution which will be the fastest and easiest to develop (at a reasonible cost but not necessarly no cost). The ideal situation would be if I can find a comprehensive package including low-level staff (drivers, stacks, etc...) on both PC and FPGA sides as well as some templates of web server or control applications which I could simply adapt/enrich to make my own. In other words, since I am more an FPGA developper than a software developper, I would highly prefer to start from a working ensemble and modify it rather than trying to build or assemble a new one (unless it is quite straight forward without unknowns). Thanks to all your tips, I have now identified the following potential solutions : - USB approach http://www.slscorp.com/pages/ipusb20sls.php - Ethernet approach http://www.altera.com/support/exampl..._tutorial.html (http://www.altera.com/support/examples/nios2/exm-micro_tutorial.html) http://www.iniche.com/nios.php http://www.sics.se/~adam/uip/index.php/main_page http://www.micrium.com/products/tcp-..._download.html (http://www.micrium.com/products/tcp-ip/tcp-ip_download.html) For those having experience in some of these and knowing now my target (find a ready-to-use/modify or straight forward and simple comprehensive solution), which one of the above options would you recommend ? Note : this message was also posted in "Embedded web-server in FPGA" thread since it overlaps both threads.
