18 years agoPC software for FPGA control through USB port
On one side you have developped a PC control software (i.e. Visual C++ .net application). On the other side you have a Cyclone III development kit. What is the best/simplest way to make them communic...
18 years ago --- Quote Start --- What about RS485? Seems to be implemented in less than a day. I used wxwidgets several times to setup programs to capture Com-Port Data, which is very quick. --- Quote End --- I second this recommendation. Unless high data rates is a requirement, you'll be better off using simple serial communication over RS-232. If connectors is a problem, simple USB<->RS232 converters are cheap and plentiful.
