17 years agoOutput amplitute from an NCO
Am i right in thinking that the output amplitutde from the NCO is not constant over different frequencies?
17 years agoSo this must be a common problem when using the DAC on the S180 then?
I am surprised that it doesn't have this feature in the DAC like you mentioned some other ones do to counter act the sinc droop? Also found this about the theory if anyone else is interested. http://www.maxim-ic.com/appnotes.cfm/an_pk/3853
