17 years agoOutput amplitute from an NCO
Am i right in thinking that the output amplitutde from the NCO is not constant over different frequencies?
17 years agoI will assume now your DAC has no sinc correction. You will get amplitude droop(due to hold device similar to low pass average filter for the duration of one sample). This droop goes towards zero at Fs and its multiples(after successive lobes). The remedy is to add inverse since filter somewhere e.g. in the fpga or in the dac(some dac have it) or in the analogue domain.
There should be no problem with lower frequencies as they are passed best
