15 years agoOut of memory in module quartus_fit.exe
Hi, I am trying to map a 256 byte memory in stratix V. My design synthesizes properly but while fitting it gives an error "Out of memory in module quartus_fit.exe". I am wondering what can be t...
15 years agoBasically, you do not have enough memory. IIRC, you need a minumum of 3GB phyisical memory (available) to compile stratix 5 properly. If you have a 32 bit system, then you actually only have 3GB Max available to windows becuase of system overheads. There is a boot setting somewhere that increases the 2GB cap per process of physical memory, but I cannot recall where that is.
I would recommend moving to a 64-bit machine.
