18 years agoOpen drain usage with internal pullups
Is it possible to use the programmable internal pullup for open drain operation, without adding an external pullup? I guess it should work without problems, besides performance. If so, what wou...
18 years agoFor any strange reason, the datasheets strictly avoid to tell this simple and obvious fact. However, there's a knowledge base entry, that confirms it for Cylone.
--- Quote Start --- The value of the programmable pull-up resistor for Cyclone® series devices in user mode can be found by referring to the Rconf specification in the "DC and Switching Characteristics" chapter of the respective device handbook. --- Quote End ---
