14 years agoOn/Off led
unable to turn on/off led. the component does not trigger does anyone knows why? --main file architecture Behavioral of DigitaleKlok is
component OnOff is
port (
14 years agoI think I have corrected the portmap, but still nothing happens when I change the switch state.
-- main file
port (
Dselect : in std_logic; -- 24000000HZ
SW : in std_logic_vector(3 downto 0);
KEY : in std_logic_vector(3 downto 0);
LEDR : out std_logic_vector(9 downto 0);
HEX0, HEX1, HEX2, HEX3 : out std_logic_vector(0 to 6) --> Display_select
architecture Behavioral of test is
component leds is
port (
led_state : in std_logic_vector(1 downto 0);
end component ;
signal Alarm_state : std_logic_vector(1 downto 0); --> 01,10,11
begin
process(Clock)
begin
if (SW(2) = '1') then
if (hour = alarm_hour) then
if (minute = alarm_minute) then
alarm <= 1;
end if;
Alarm_state <="01";
else
Alarm_state <="10";
alarm <= 0;
end if;
end process;
test: leds port map (Alarm_state, LEDR);
end Behavioral;
library IEEE;
use IEEE.std_logic_1164.all;
entity Leds is
port (
end entity Leds;
architecture Behavioral of Leds is
begin
process(led_state)
begin
if(Clock'event and Clock='1') then
if (led_state = "10") then
LEDR(9) <= '1';
end if;
if (led_state = "01") then
LEDR(9) <= '0';
end if;
end if;
end process;
end Behavioral;
