18 years agoon chip sd ram
hi, i want build a on chip ram memory of 21kb. i wish acivate the on chip sd ram memory with spoc builder. while adding the module i faced the error" onchip_mem.s1": must be connected to av...
18 years agoYou don't need the tri-state bridge - this is for adding external memory. The internal on-chip memory just needs connecting to the cpu's data and/or instruction master - click on the blob(s) in the connection column. If this column is not visible make it so with the View menu.
