15 years agoon chip memory problem
hello. what is the ideal size for on chip memory if my code is written using c programming which includes dma, performance counter and etc... currently, i am using default size which is 4096 bytes on...
15 years agoas long as you use different areas there isn't any problem using the sdram for both code and data. You'll be very limited with 20k anyway.
Did you use the sive optimization, small C library and reduced drivers?
