15 years agoon chip memory problem
hello. what is the ideal size for on chip memory if my code is written using c programming which includes dma, performance counter and etc... currently, i am using default size which is 4096 bytes on...
15 years agoIt depends on your code and optimization level. If you use the optimise for size and the small C library you can use a small on-chip memory but 4k is really low... I think that 16k would be a minimum.
