13 years agoOK to leave Cyclone IV E PLL Power pins grounded or connected to VCCINT?
I am building a Cyclone IV E design that doesn't use the PLLs. Do I still need to provide a 2.5V power rail for the PLL power pins? Or can I just connect them to ground or VCCINT (1.2V)?
From the Cyclone IV documentation (AN 592: Cyclone IV Design Guidelines): "Connect all PLL power pins to reduce noise even if the design does not use all the PLLs—VCCA to 2.5 V and VCCD_PLL to 1.2 V or 1.0 V" This doesn't directly address the case where the design doesn't use ANY PLLs. It would sure make things easier if I had one less voltage regulator to worry about!1 Reply
You can't save voltage regulators, because 1.2V and 2.5 V supply are always required. Read the chapter power-on reset circuitry to understand why.
