OCT usage in Cyclone V
As per my understanding, to use the OCT function, the RZQ pins are connected to GND through an
external 100- or 240- reference resistor depending on the desired OCT impedance.
As for your question #2, you can just add the Weak Pull-Up Resistor column in the Editor table by customizing the table. And then you can just toggle the option to "On" for the pin that you desired to use the OCT function.
Aqid Ayman
- Lilian_614 years ago
The RZQ pin has connected to GND through an external 100ohm reference resistor on board.
From your reply, my understanding is the ALTOCT is not needed, and just do setting in Assignment Editor is ok.
And in Assignment Editor,I opened the OCT function for the pins like below.
But when I test on board, I found the signals gone on pins.
What I mean is, the pins work before I added the OCT function, but when I do the above setting, the pins doesn't work at all. Looks the setting disabled the pins function.
Could you help more on this? Not sure that my setting in Editor is correct.
Lilian
- Mklusal2 years ago
Hi Lilian.
Did you found a solution?
I am facing the same issue.
Milos
