15 years agoNumber Scaling
Hi, What is the most efficient way to scale numbers into the range of -1, 1 in Verilog using Cyclone II? That is the fastest code with least resources? are there any free IP cores from Altera o...
15 years agoHi Dave,
Thanks .. The thing is that I have a random Integer input in the 0 - 579 range, without any fractions, simply integers :) ...(xmin-xmax) This need be scaled to the -1 to 1 range (ymin-ymax) following this rule y = (ymax-ymin)*(x-xmin)/(xmax-xmin) + ymin; In my application it is: y = (2*x)/579-1 So based on what you said, to implement the above formula, all I need to do is shift my integer 10 bits to the right?? and then subtract one? Note that the following Hardware stages are in signed fixed point format with <S, M, N> = <1 sign,5 integer,10 fraction>, is the result readily available for use in the following stages?? or scaling is further needed? Thanks
