17 years agonStatus can't go high
I have just finished my pcb of EP3C25F324, but it can't work when I power on the board, all user IO pins stayed high, the nSTATUS remaid low, and nCONFIG statyed high. Is't the problem of POR? Or ...
16 years agoI have solved the JTAG problem. The reason is that VCCINT and VCCA were not powered correctly.
--- Quote Start --- I met the same problem with you: the nstatus can not go high and I can't configured the EP3C40 via JTAG neither. So have anyone solved this problem? Maybe you can help me with your experience. Many thanks. --- Quote End ---
