17 years agonStatus can't go high
I have just finished my pcb of EP3C25F324, but it can't work when I power on the board, all user IO pins stayed high, the nSTATUS remaid low, and nCONFIG statyed high. Is't the problem of POR? Or ...
16 years agoJust following up to see if you managed to resolve the problem, need more help, moved on to other things, etc... ???
If you resolved it... what did you determine the root cause of the problem to be? What was your resolution?
