Not able to generate hps_iws_handoff folder
Hi sgannava,
It mentioned quartus pro 24.1 from the document. The quartus version is updated from time to time as the document is updated.
Anyway, the quartus version related mainly for the GHRD(Golden Hardware Reference Design).
The GSRD(Golden Software Reference Design) is not much related to the Quartus version being used.
The GSRD has the steps below mentioned in the document with is the part where it relates to the GHRD. I think you can use your exisiting GHRD build where it will also have the hps.xml file.
"Convert hps.xml handoff file to include file to be used by the device tree:"
You can still use older quartus version to test it out. Some of the steps only trying to source the tools from the specific Quartus version being used. Eventually you will build different part of the required files for system to boot up.
You mainly need to focus on is how your system going to boot up either from QSPI flash or sd card or... where you can select the topic from the beginning of the web page.
Aik Eu
