16 years agoNo ouput for Modelsim DDR SDRAM Simulation
Dear all, In my modelsim simulation of DDR SDRAM write operation, I observed pulse in "local_write_request", "local_burstbegin", and changes in "local_address", "local_wdata", however, I didn'...
15 years agoYes, I solved this problem.
It was a long time ago. From my memory, you need to set the simulation time very long, >80 us? and you see the DDR controller and memory activity after a long time, especially if you set calibration in the DDR controller, it will take a long time to do calibration or other process before memory access. Hope it helps. --- Quote Start --- I was wondering if you had solved your problem with Modelsim, and if so, what did you do to fix it. I seem to be experiencing a similar problem. I'm seeing local interface reponses but nothing between the DDR controller and memory. Thanks. --- Quote End ---
