16 years agoNiosII DMA Tutorial
Hello, may I know where can I get NiosII DMA Tutorial? Currently, I am doing a project to implement DMA on FPGA board. So I would to refer to some tutorials that can help me. Thanks.
15 years agoYou understood correctly. That sequence is correct.
Anyway I don't know how to make the RD signal available outside the sopc system. You must expose the Avalon PIO read (or select) signal, so I think you probably need a modified version of the pio core. Maybe there's a way to export that signal, but I've never made something alike. You can try this workaround: use a tristate bus with a fake sram component; discard address,wr and rd signals; connect data to your fifo and use cs signal to update fifo output.
