13 years agonios2-terminal and jtag
Hello all, I am running Nios2 on Ubuntu 12LTS and I have received the following error when trying to run nios2-terminal: $ sudo bash ./nios2-terminal ./nios2-terminal-wrapped: error while ...
13 years agoThank you.
This is useful, however I cannot proceed beyond killall jtagd. I received the following error when I perform the following at command line $ killall jtagd jtagd(1564): Operation not permitted jtagd: no process found and at the nios2 command shell: # killall jtagd # jtagconfig 1) USB-Blaster [8-1] 020F30DD The problem is still there.. no luck!
