13 years agonios2-terminal and jtag
Hello all, I am running Nios2 on Ubuntu 12LTS and I have received the following error when trying to run nios2-terminal: $ sudo bash ./nios2-terminal ./nios2-terminal-wrapped: error while ...
13 years agoI have solved the library issue, now I am receiving the following
/nios2eds# nios2-terminal nios2-terminal: There are no JTAG UARTs available which match the --device and nios2-terminal: --instance options you provided. This happens in Nios2 command shell. If i run jtagconfig in Nios2 command shell, I recieved: nios2eds# jtagconfig 1) USB-Blaster [8-1] 020F30DD It is not recognising the device name.. Can this be an issue too. If so, how do I overcome this. Thanks
