14 years ago
nios2-flash-programmer : elf & sof
Hi all
I have a zImage that uses SDRAM.
this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server
when I use nios2 shell: nios2-download-g zImage & nios2-terminal
it works well and the application set to launch at startup is working properly (ping 192.168.10.180 => ok)
Now i need to enable the system to start from power on so
I - from quartus i use " convert programming files " to program .jic file in EPCS16 ==> OK
II - zImage into cfi flash ( base = 0x02800000 End = 0x02FFFFFF)
1- in SOPC, jtag_uart: NO_interactive_windows and nios_cpu reset vector 0x02800000
2- elf2flash - base = 0x02800000 - end = 0x02FFFFFF - reset = 0x02800000 - input = zImage - output = uc_flash.flash - boot = / cygdrive/e/01_Application/Altera/nios2eds/components/altera_nios2/boot_loader_cfi . srec
==> OK
3-nios2-flash-programmer --base=0x02800000 uc_flash.flash
==> download ok , checksum ok, leaving target processor paused
When I reboot and I ping 192.168.10.180 nothing happens.
I don't know if I missed a step!!!
thanks for help
    I have to use an RS232 to debug ? There is no ethernet interface to do it?
