14 years agonios2-flash-programmer : elf & sof
Hi all
I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: nios2-download-g zImage & nios2-terminal it works well and the application set to launch at startup is working properly (ping 192.168.10.180 => ok) Now i need to enable the system to start from power on so I - from quartus i use " convert programming files " to program .jic file in EPCS16 ==> OK II - zImage into cfi flash ( base = 0x02800000 End = 0x02FFFFFF) 1- in SOPC, jtag_uart: NO_interactive_windows and nios_cpu reset vector 0x02800000 2- elf2flash - base = 0x02800000 - end = 0x02FFFFFF - reset = 0x02800000 - input = zImage - output = uc_flash.flash - boot = / cygdrive/e/01_Application/Altera/nios2eds/components/altera_nios2/boot_loader_cfi . srec ==> OK 3-nios2-flash-programmer --base=0x02800000 uc_flash.flash ==> download ok , checksum ok, leaving target processor paused When I reboot and I ping 192.168.10.180 nothing happens. I don't know if I missed a step!!! thanks for help
