15 years agonios stops.
my nios system (fifo, dma, custom component )stops executing at seemingly random times. mostly in the middle of a printf. can this be because of an interrupt, arent those ignored if i choose no...
15 years agoIf you are sure about your hardware (timing requirements met, devices fully tested, ...)
then probably you have a stack overflow. Do you use big local variables (struct, arrays), recursive code or a lot of nested calls?
