15 years agoNios programming to De2 board fails
Hi, I am using the Nios2 9.1sp2 to build my .c file. and then when I built the project with no problem and run simulation in Nios II instruction set simulator also no problem. However, when I try to ...
15 years agoFew things to check.
Are you sure this design meets all the timings? Is the reset given correctly? Is the CPU and main memory connected correctly? Since you have done the simulation, I would guess the timing rather than the connectivity. You might want to slows down the system and CPU clock speed just in case.
