15 years agoNIOS is generating Read Signal Twice.
Hi, There is a custom interface of NIOS with a device, having own DSP-Processor. Interface is 16-bit data bus. While reading the data NIOS is generating CSn and RD Enable twice. Please hel...
15 years agoHi, Cris,
Thanks for your kind information, my issue get resolved. I took 32 bit bus from NIOS and mapped the Lower 16 bit with custom interface. Thanks a lot to all replies. --- Quote Start --- The misunderstanding is related to the fact that NIOS always performs 32bit read accesses, even if you explicitly use IORD_16DIRECT or IORD_8DIRECT: in these cases you'll always get multiple CS and RD strobes. This can be annoying if your external address is a fifo or some register which is supposed to change at every read access. The solution I used in a similar case is using a 32bit external data bus and connecting only the 8 or 16 bits I need; this way I always perform a single 32bit access and discard extra bits. --- Quote End ---
