15 years agoNIOS is generating Read Signal Twice.
Hi, There is a custom interface of NIOS with a device, having own DSP-Processor. Interface is 16-bit data bus. While reading the data NIOS is generating CSn and RD Enable twice. Please hel...
15 years agoThe misunderstanding is related to the fact that NIOS always performs 32bit read accesses, even if you explicitly use IORD_16DIRECT or IORD_8DIRECT: in these cases you'll always get multiple CS and RD strobes.
This can be annoying if your external address is a fifo or some register which is supposed to change at every read access. The solution I used in a similar case is using a 32bit external data bus and connecting only the 8 or 16 bits I need; this way I always perform a single 32bit access and discard extra bits.
